This is what they have listed on their website:
$1995
$ 800
$ 352
$ 790
$ 299
$4236 | DC Solar Air Conditioner 12000BTU
3 x 340W PV Panels
3-panel Flush Mount Rail Kit (72C3)
4 x Trojan SCS225 12V 130AH batteries
1 x PWM Charge Controller
~Total System Estimated Cost
*Wiring & connection materials not included. Includes estimated battery cost of $790, batteries supplied by customer and are not shipped or billed by HotSpot. |
-You can obtain solar panels much cheaper than this.
www.santansolar.com has new and used panels and craigslist may be on option in your area.
-Mounting can be done in a variety of cost saving ways including using super strut from your local big box store. Youtube has a lot of examples of ways to mount panels.
-$299 for a PWM charge controller is high and they don't mention the brand. You can obtain a top of the line Victron MPPT from Amazon or baymarinesupply.com.
-The batteries are lead acid in this example. Most here use LiFePO4 (Lithium Iron Phosphate). With lead acid you can only use about 50% and LiFePO4 you can use up to 100% (90% recommended). So they list four 12 volt batteries to make a 48 volt bank at 130ah. That equals about (48x130) 6240 watt hours. Now divide that 1/2 and that is around the actual usable watt hours, so 3120 watt hours. The spec sheet for the AC unit says it uses about 500 watts per hour under "normal" cooling conditions. So maybe about 5-6 hours of use when there is no sun. They mention that they do not sell these batteries and it's just an estimate, but they carry AGM batteries for sale. So you could supply your own here.
They also note that wires, fuses, shipping, etc are not included in this price. So you're probably realistically looking at around $5000.
I built out my system to run a 12,000 BTU portable AC unit and several other devices. It cost about $5700 and is about 3.5x as large as the one they list, but a lot of the cost is the AC unit in their estimate and mine was only $450. I assume that is a decent AC unit to cost that much.
I don't have experience with DC only AC units, so hard for me to give any advice here. Suggest reading reviews and buy the AC stand alone and build a system around it to save money. Will did a recent series on him running an AC unit in his shed that might help. It's rated at 440 watts, so right around what the one you listed uses. He uses all in one units and that save a lot of money as well, but do have drawbacks (fan noise, high idle consumption).
If you had this solar system, would it be just to run an AC unit or do you have a need for it to run other devices as well? Where is the AC being installed (gar
Damn thank you so much. That was very helpful for sure!!
