inowhavesolar
- Jun 15, 2022
- 19
My wife and I are having this debate on which would be better for keeping the house cool, and keeping electricity bill low. There are 2 options:
- Purchase a high-efficiency window AC unit (12000+ BTU), and place it in the living room. Solar+battery will keep this running 24/7, blowing cold air into the room, which will slowly make its way throughout the house, lowering the house temp, thereby making the whole-house AC not needing to run. Pros: Powered 100% by solar. Keeps main AC from running. Cons: Visually unappealing window unit in main living space (ie: looks "cheap"). Cold air might not permeate to far edge rooms the house.
- Move 50A AC breaker to critical loads panel. Perfectly sunny days should make 5-6K watts from panels, which will offset running the AC. (Sticker on the compressor unit says 35A running load x 240v = 8400W). The battery will supplement the remaining watts, which charges from grid once it drops below 30% SOC. Pros: Whole house AC. No unsightly window unit. Cons: Solar+Battery might only give 1-3 cycles of "solar powered AC" per day. The AC will probably cycle 15-20 times a day during 99F+ summer months.
