John Frum
Tell me your problems
- Nov 30, 2019
- 15,233
Same concept as what?Think about the f150 power-on-board as an example- isn't that the same concept?
The RV ground is connected to the chassis.I guess you could end up with dc return over the ac ground or neutral.
Which would make a ground loop with the 7-pin ground.
If both the tow vehicle and trailer side are floating it should be ok.
@eric_h is the tow vehicle inverter floating?
Is the trailer house system floating?
Actually if either side is floating it should be ok.
As what I'm looking to do.Same concept as what?
The word originally in this context makes no sense to me.The RV ground is connected to the chassis.
TV does not originally have ground.
I would guess the f-150 power on board inverter is bonded to the chassis.As what I'm looking to do.
Thank you. Why would I lose lights on the trailer?I'd be curious if your trailer lights still work when you have the 120V from the truck connected. If it impacts the trailer ground, you could end up impacting the trailer lights or brakes.
IF something were to happen and you lost lights or trailer brakes, it would come with HUGE liability in an accident, your carrier might even disclaim that portion of the case based on the alterations. I'm not saying it's likely, just saying if something happened, you would be in a really bad spot.
Honestly, I'd just charge off the trailer plug to get what you can get on the road, and leave it all alone. Converting 12v to 120v in the truck, then using 120v to charge 12v in the trailer across a separate connection seems like a lot of conversion losses and potential failure points while going down the road.
Charging it while it's parked, do whatever you decide makes sense, but on the road, be careful.
I don't know yet. Just had the idea last night and haven't had the chance to checkThe word originally in this context makes no sense to me.
Is the tow vehicle inverter ground lug connected bonded to the chassis?
That gives me a idea how to easily check this.I don't know yet. Just had the idea last night and haven't had the chance to check
Will do soon, but wanted to know if I'm completely off, before I unscrewed anything...
smoothJoey, His concept doesn't mess up the 7-pin with anything related to 120-VAC, there's an entirely separate cord. The TV's 120-VAC should definitely be generating that 60Hz power with the approximated "sine wave" centered around chassis ground (as zero voltage). The "neutral", supporting return current in the same 60Hz sine wave pattern, must *never* be interconnected with Trailer or TV ground - ground is only connected with the green "safety grounding" wire.I guess you could end up with dc return over the ac ground or neutral.
At the risk of repeating myself if both the inverter's grounding lugs are bonded to the chassis then dc return currrent from the 7-pin could have a new path back to source, no?smoothJoey, His concept doesn't mess up the 7-pin with anything related to 120-VAC, there's an entirely separate cord. The TV's 120-VAC should definitely be generating that 60Hz power with the approximated "sine wave" centered around chassis ground (as zero voltage). The "neutral", supporting return current in the same 60Hz sine wave pattern, must *never* be interconnected with Trailer or TV ground - ground is only connected with the green "safety grounding" wire.
I must have missed that.My 1st concern would be with the quality of "modified sine wave versus so-called "pure sine wave" coming out of the Inverter, and the receiving trailer power converter ability to handle that somewhat distorted.
I believe he said the trailer has an inverter_charger but clean power will likely be required.The Converter is expecting "clean" power from a utility, and maybe the THD coming out from the Inverter will cause the trailer's converter to die young.
I think @eric_h said the circuit is GFCI protected.My second concern would be the safety of the 120-V cord, for the possible case of a "hot" disconnect.
Yes. The TV inverter is definitely not pure sine wave and I thought to possibly power only the fridge with it, bypassing the RV charger.smoothJoey, His concept doesn't mess up the 7-pin with anything related to 120-VAC, there's an entirely separate cord. The TV's 120-VAC should definitely be generating that 60Hz power with the approximated "sine wave" centered around chassis ground (as zero voltage). The "neutral", supporting return current in the same 60Hz sine wave pattern, must *never* be interconnected with Trailer or TV ground - ground is only connected with the green "safety grounding" wire.
My 1st concern would be with the quality of "modified sine wave versus so-called "pure sine wave" coming out of the Inverter, and the receiving trailer power converter ability to handle that somewhat distorted. The Converter is expecting "clean" power from a utility, and maybe the THD coming out from the Inverter will cause the trailer's converter to die young.
That was @rickst29 good idea if memory serves.Yes. The TV inverter is definitely not pure sine wave and I thought to possibly power only the fridge with it, bypassing the RV charger.
That said, this is becoming too complex, with safety concerns, that I'm abandoning the idea.
I might go with an idea I saw here to step up the 12v alternator to 48v to use a lighter wire and less drop, and step down in the RV, going into the circuit as charge, and connect them via the Phillips safe 2 pole sockets or Anderson plugs.
Just trying to feed the fridge and battery as I drive without running 60 feet of expensive cables between the two...
Thank you all!
Most probably, will need to check, but I assume Ram did but go the extra mile here.I must have missed that.
@eric_h is the tow vehicle inverter modified sign wave?
IndeedI believe he said the trailer has an inverter_charger but clean power will likely be required.
I was thinking to do that myself anyways.I think @eric_h said the circuit is GFCI protected.
DefinitelyThat was @rickst29 good idea if memory serves.
Fridge is 360w AC. 7 way is not even close, unfortunately.@eric_h if you just want to power the fridge then the 7-pin should be adequate to the task.
You didn't respond to my question about how the breakaway system is powered.
Understood.Fridge is 360w AC. 7 way is not even close, unfortunately.
I don't.Breakaway is connected to house battery, if you recall our long conversation in the matter a while ago
What you're now describing which could go through the "trailer battery charge" wire and return on the shared grounding wire of the Bargman cable (and plug) you already have. That's what I have, stepping up to 36V under the hood and running into a MPPT Solar controller (rather than a fixed voltage "step-down") - providing power to the entire Trailer (including battery charge), and not just dedicated to the fridge.Yes. The TV inverter is definitely not pure sine wave and I thought to possibly power only the fridge with it, bypassing the RV charger.
Thank you all!
