I've built a 48V 280AH 16 cell battery for an emergency backup system for my house. Since it incorporates a 6000W split phase Growatt controller/charger/inverter, I decided to move my water well circuit off grid to give the system something to do between blackouts. The well barely consumes 4Kwh a month and my panels produce about 5Kw in full sun. My panels are broken up into 5 strings of 3 panels each connected through a combiner box with individual fuses on each string. It's a simple matter to enable or disable however many strings I need depending on how many kw I need for any particular load. One string keeps the battery at virtually 100% even with the well pump doing its normal duty. Here's the question. How important is it to allow the LIPO cells to do a deep discharge down to about 20% periodically and how often should I turn off all the panels and let the well slowly drain the battery? I'm pretty sure that to keep maximum capacity you need to "drain" your battery occasionally. I'm just not sure how important that is and how often it should be done. Advise from someone experienced in trashing batteries by keeping them perpetually fully charged would be appreciated.
