Basics.
Grid Power: Single Phase - 240v - 100amps
Usage: Home
Consumption: Average Daily = 21.37 kWh
Panel:
The Brief.
I want to connect solar to my house for a number of reasons:
I've contacted a Solar retailer and they've advised the below would meet my needs:
6.6kw Hybrid System
On top of this I'll be sourcing a LiFePO4 48v 10KWh/200AH battery of some form.
Considerations.
1. All grid connected/tied inverters/Panels must be on the approved lists:
- Inverters - https://www.solar.vic.gov.au/sites/...ter-product-list-as-of-22-September-2023.xlsx
- Panels - https://www.solar.vic.gov.au/sites/...nel-product-list-as-of-22-September-2023.xlsx
2. All work must be completed by a qualified/licensed Electrician (labor is expensive - expect. $100 per/hr)
The Problem.
The back-up/UPS power output for the majority of inverters is limited to somewhere between 20-30amps and most require a ATS/Breaker of some form limited to the same amperage.
This is not enough to run the whole house and no electrician is going to connect the whole house to a ATS of 30 amps considering the theoretical max usage into the house is 80-100amps (Stove/Aircon/Microwave/Hairdryer all on at the same time etc.).
Solutions I've thought of but don't think are ideal:
How can I solve this problem?
Thank-you in advance.
B.
Usage: Home
Panel:
The Brief.
- Back-up/Redundancy - I want to make sure I can run the majority of the house on backup power that's automatically switched (Help needed here - See below)
- Saving Money (don't need help/advice on this)
6.6kw Hybrid System
- 15 x Jinko Solar Tiger Neo N-Type 440W Black Frame 108 Half-Cut Cells Mono (JKM440N-54HL4R-V)
- 1 x Inverter- Growatt SPH 5kW 1 Phase 2 MPPT Hybrid BL-UP (SPH 5000TL BL-UP (AS4777-2 2020))
- 1 x Monitoring Inbuilt Wi-Fi
Considerations.
The Problem.
- Bigger inverter - Still limited to 30amps output (remember the list above)
- Multiple inverters - Am I going to need 3 x SPH5000?
- Mix of inverters - Use the SPH5000 connected to the grid then something like a 'uncertified' inverted specifically for the back-up power and leave it off the grid e.g. https://www.ebay.com.au/itm/1658859...uid=H4ZGbnq5QSy&widget_ver=artemis&media=COPY
B.
