Hello,
Is it possible to run the Deye as an offgrid inverter and only switch on the grid when needed to charge the batteries? I see in the battery setup that there is a "grid signal" feature, which could potentially be used to control an external "normally open" relay or contactor to connect the grid to the inverter when the batteries fall too low.
I realise I could connect the grid to the gen port and use the gen signal to do this, but I also have a generator which I want to switch on when the batteries fall too low AND the grid is not present.
