More info needed. You back fed the AC input or output? Wiring diagram?I have a Eg4 6.5kw-6500ex 48v inverter and 3 eg4 life-power4 batteries, I threw the wrong breaker and back fed ac power to the inverter. Now batteries trip to fault, and inverter shows 6p. New to solar, but not bad news.
When you say solar is in the barn I'm assuming you mean the inverter, panels and batteries?... A diagram or photos would be very helpful.... So you fed/backfed AC from the inverter/solar in the barn to the house panel with the mains off and the pump ran, then you turned the mains on with the inverter/solar still feeding AC to the panel and the out of sync phases collided resulting in scent of magic smoke?Solar is in the barn working fine, I wanted to see if i could run the pump in the house, i turned off main breaker in the house and ran solar to that box worked fine. I turned on main breaker to house without disconnecting solar, BMS fried? Thanks
The main did not trip. when i got back to the barn I disconnected the solar to the house, the inverter was running in bypass on acv, in the barn still had power to loads. all 3 batteries were tripped, tried to reset and reconnect to inverter with com cable, there was allot of clicking from batteries and all 3 trip-default code is 6p, battery is not connected. I think BMS is done, inverter is still running i will try user-defind tomorrow see what happens. thanksWhen you say solar is in the barn I'm assuming you mean the inverter, panels and batteries?... A diagram or photos would be very helpful.... So you fed/backfed AC from the inverter/solar in the barn to the house panel with the mains off and the pump ran, then you turned the mains on with the inverter/solar still feeding AC to the panel and the out of sync phases collided resulting in scent of magic smoke?
If the above assumption is correct you likely fried alot more than a BMS.
Did the mains breaker trip after you flipped it back on? What does the manual for your EG4 state for the error you are seeing?
Going to check tomorrow. Thanks for response.If you disconnect the batteries from the inverter do they still trip out?
Do they then have an output voltage?
You have blown the inverter, the CPU and bypass relays are still running OK.
Batteries should be fine, it's the 48v bus in the inverter that shat the bed.
