Hi,
I have a Sungoldpower 8K 48V Hybrid inverter and around 20kwh battery pack.
This is the link of the inverter -
Today, the inverter shut off the ‘AC out’ and threw a fault code 14 (Overload inverter). At that time, the following items were running -
1. Space heater 1500W
2. Microwave 1600W <—Everything went out after Microwave ran for 5 seconds
3. TV with Speakers 400W
4. Misc items (couple of lights, router/idle load etc.) 500W
So altogether, the load was at around 4000W. The batteries at that time were around 55% SOC.
Can somebody please share their experience if they had such issue with this type of inverter (fault code 14 with this low of a load)? Is there any specific parameter that I need to check or tweak on the inverter?
BTW - I have been using the dryer everyday (during daytime) from the last couple of days for almost one hour (5000W) without any issue
Thank you for reading this issue and your valuable response.
Regards,
MV
8KW 48V Split Phase Solar Inverter
Highlight: ★ All in one unit: 8KW Pure Sine Wave Solar Inverter Combined with Max 200A battery charging, 2 MPPT Solar controller inbuilt, Max.Voltage of Open Circuit : 500VDC, Split phase (120V/240V) or Single phase (120v) output. Wifi module is included, which allows the user to view the...
sungoldpower.com
Regards,
MV
