Thank you very much for the prompt answer. I am using an Epever 40amp solar charge controller with 400w solar panel already on. How much can I go to Watts with this system? Also, 2 Battle Born batteries in parallel too.If they have same voltage VMP then, it should be ok, as long as your wire is large enough, and the charge controller can handle the wattage.
So adding another 200W panel won't be good for the system 600/12=50amps. Mine is 40 amps. Not even another 100w. Thank you so much for the assistance JADF400w at 12v is only 33Amps at max output... 500 at max output is only 41 ish amps... so it would be fine.
Voltage Open Current.Sorry for my ignorance. ¿What VOC stands for? Also, can you help me with the last question? Thank you
Thank you very much, did what you told me yesterday came out ok. Will you please give a hint on my yesterday 3:38 pm question. I have excellent sun hours here in my place and my main objective was to power my fridges (2) with my solar panels and my power inverter, using my sun hours and try to lower my Grid bill which is really high. I appreciate the help given. Continue learning. JADFVoltage Open Current.
It means what the panel produces when nothing is connected. It is the maximum voltage the panel should be capable of, but it can go higher in a low load cold sunny day.
I ALREADY ANSWER THAT IN MY PREVIOUS MESSAGES, WHAT I WANTED TO KNOW IS THAT YOU TOLD ME, THAT I CAN ELIMINATE SOME OF MY PRESENT BOARD SETUP TO GAIN MORE POWER. FOR EXA. I DO NOT PLAN TO USE THE DC POWER FROM THE DC CONNECTION AT THE BUTTON RIGHT OF THE PICTURE. SO, IF I GOT RID OF THE RED AND BLACK CABLES FROM THAT CONNECTION TO THE INVERTER, I SHOULD GET MORE POWER FROM THE PANELS TO THE BATTERY. AM I CORRECT? IF YOU MAY HAVE SOMETHING DIFFERENT, PLEASE LET ME KNOW. JADFView attachment 15540
This eliminates all the mc4 y connectors.
400x 8 hours would give you 3200Wh, but you would have to move the panels to face the sun all day to get that.
