offgriddle
"FOREVER BEGINNING"
Fotos 1& 2, DIY econo- project: 60 amps of lifepo batteries plus wiring installed inside a heavy steel enclosure. 20 amp hour shore power lifepo battery charger, 1,200 watt 110VAC inverter and mppt controller mounted externally. 63 amp Cam switch will allow easy selection between the inverter power or propane generator power with a common output feeding the cabin electrical panel.
Foto 3, Today windy and cold but scrumptious: The solar panel farm is soon to double in capacity using the new panels presently in storage, (project NO 300,673). Currently providing power to operate a small freezer and provides basic electricity for two cabins.
