The one who brought us our solar panel ( 275 watt, 31v, rated current 8.9amps) is planning to use the same sized one for his boat, which is sitting by his house, along with the same controller (20A-10A-Epever-MPPT-Solar-Charge-Controller-12V-24V-Battery-Regulator-Max-PV-60V). So, as I understand it, his panel is bigger sized than what he needs. Can he just cut off those special ends on the panel's cable and use thick cable 10AWG and make a good connection directly? Thanks
