offgridliving456
I'm in the process of revising a 6kWh vehicle build. I've replaced my batteries with a single larger that has a JBD BMS with app controlled mosfet disconnects. The system is protected with a class-T fuse immediately after the battery. Now that I can software control charge/discharge mosfets, do I really need to retain my manual disconnect switch?
In the case of an emergency need to disconnect I'd be relying on the fuse as the manual disconnect is not quick to reach typically and of course if very close to the potential source of the problem. The switch, a Blue Sea, 300A continuous rated switch works fine but is my most significant source of resistance and now that I can use the app to disconnect for system maintenance I'm considering removing the manual switch. I realize opinions will vary, please share yours.
Thoughts?
Thoughts?
