Does WatchPower Wifi App work with any module
logslogs
MR. K
Pakistan
I have an Inverex Veyron II 6kw Hybrid Inverter that comes with an app named i.Solar. The only other solar inverters that use this app, seem to be MPP Solar inverters. For example here: https://mppsolar.com/manual/ACCESSO...FI MODULE/WIFI APP - i.Solar SOP 20240103.pdf
This is the app: https://play.google.com/store/apps/details?id=uni.UNI199C480&hl=en&gl=US
The i.solar app is really terrible, so I wanted to know if I can use WatchPower wifi instead.
Do you think I will be able to configure and run WatchPower instead?
Not sure, but after trying to use WatchPower, and getting very frustrated, I finally went with Solar Assistant - very happy with this decision.
You may want to confirm with Solar Assistant if the inverter you have is supported before you spend your money on solar assistant.
