It 5kva/4kw inverter specs DC input 48 voltage 93A ,Solar charger mode min 36 VDC system Voltage 48 VDC and maximum Solar voltage (VOC) 105 VDC.
I installed 08 pannals 47 vol 12 a (585 Watt). 02 pannals in series with 04 pair and then parreller all 04 so it's 96 volt with 48 amp.
The problem when in contact it with the said inverter so it shows 96 volt on display after 5 second when start battery charging so the 96 volts drop to 50 volt and the DC protection breaker heat up and break and goes to open circuit.
I replaced the inverter controller board with another donor board but same result..so what the problem.one thing to mention the donor board have no op07 current sence ic so I remove from own board to donor board
Plz help
Plz help
