jimbob78cj
I am building a vehicle for overlanding. I am running a standard lead acid dual battery system where one battery is designated as the starting battery and the other as an accessory battery. The batteries are connected together and charged by the alternator while vehicle is running and the two batteries are disconnected from each other when the vehicle is off to prevent accessories from draining the starting battery. Since I have a few accessories that could drain the accessory battery too fast, I decided to add a 200W solar array to the roof and bought a Renogy Wanderer 30 amp PWM charge controller that is connected to the accessory battery to charge it while the vehicle is not running.
My problem is that when I crank the vehicle and the alternator starts charging both batteries, the Renogy controller will disable itself (all lights go off) and I have to disconnect and reconnect the panels and battery momentarily to get it back working once the vehicle is off again. If I disconnect the panels prior to starting the vehicle, all is good. Is this a design issue or a charge controller issue?
