Hi Guys,
some week ago i buy inverter in subject but documentation included into the package is not clear. I read somewhere that is like soro vm II, i download the document but have different function. i think i didn't get a good deal
maybe some one have more experience and can help me to understand
my questions:
1) Connect to battery. ( in manual see have rs232 rs485 and CAN but somewhere read that have only rs232 and rs485 )
2) i have also growatt ark 25lv battery ( unable to connect over CAN ) / BMS always blink ( actually is connect only over + and - but i not found yet the stable parameter )
3) Manage from linux or windows os ( by watchpower i can get only information, can't manage or modified parameters, must to set everything by button )
also over mpp-solar can get only information, every command in list is reject with error
monitor:~ $ mpp-solar -q localhost -c QPIGS
Command: QPIGS - General Status Parameters inquiry
Parameter Value Unit
ac_input_voltage 236.0 V
ac_input_frequency 49.9 Hz
ac_output_voltage 236.0 V
ac_output_frequency 49.9 Hz
ac_output_apparent_power 0 VA
ac_output_active_power 504 W
ac_output_load 9 %
bus_voltage 401 V
battery_voltage 53.1 V
battery_charging_current 0 A
battery_capacity 100 %
inverter_heat_sink_temperature 26 °C
pv_input_current_for_battery 0.0 A
pv_input_voltage 0.0 V
battery_voltage_from_scc 53.1 V
battery_discharge_current 0 A
is_sbu_priority_version_added 0 bool
is_configuration_changed 0 bool
is_scc_firmware_updated 0 bool
is_load_on 1 bool
is_battery_voltage_to_steady_while_charging 0 bool
is_charging_on 1 bool
is_scc_charging_on 0 bool
is_ac_charging_on 1 bool
rsv1 0 A
rsv2 0 A
pv_input_power 0 W
is_charging_to_float 0 bool
is_switched_on 1 bool
is_reserved 0 bool
- all online document is unavailable
- forget the support from easun or powland, nobody answer. Only able to sell
- Invert buyd in europe but if broken must to send back to China.
- Hope my experience can help someone to understand what is good to buy or not
reagrding my initial question any help will be appecciated.. thx?
my questions:
ac_output_load 9 %
bus_voltage 401 V
is_load_on 1 bool
rsv1 0 A
rsv2 0 A
pv_input_power 0 W
is_reserved 0 bool
