PinionRanch
I am considering the purchase of two Delta Pro's and the 240v hub so that I can power my well pump at my country property.
I'd also like to be able to power an RV trailer with 120v, but have seen some information leading me to believe that if you use the 240v hub, then there is no way to get 110-120v directly from the hub or the delta pros.
Does anyone know if that is true?
If it is.. what recommendations would be available for designing my system so that I could get both?
Any help appreciated.
Thank you, James.
- Is there an adaptor or 240v to 120v converter that I could plug into the DP 240v hub?
- Or would I need an electrical panel installed in my well pump shed, with 240v interlock (from DP hub) and some 110-120v outlets wired from the panel?
Thank you, James.
