House Batteries EcoFlow Delta Pro
TheO-GVeteran
Pennsylvania
So I’ve Got 2 EcoFlow Delta Pro batteries and the extra battery so essentially 3 batteries. I’ve got the cables to connect them all together in series. However I’m still waiting on the Double Voltage hub to arrive and it’s on back order. Can I still connect them to the house and run them without the double voltage hub even if I connect them all together?
I don't believe you can connect two Delta Pro's together without the double voltage hub.
How were you planning to "connect them to the house and run them"?
