I have a Delta Pro with an extra battery and i just got my Ultra delivered. I was thinking of selling the Delta Pro and battery but decided to keep them. I have the Ultra charging from the Delta Pro via the regular AC connection and Solar and it works great. After reading the user manual about charging the Ultra using a regular generator via the Power Input\Output port I decided I wanted to see if I could charge using the front 120v 30amp output on the Delta pro and connect it to the Power Input\Output port on the side of the Ultra. I bought the Ultra Power adapter from Ecoflow and then a NEMA TT-30P to L14-30R Adapter Cord. Once I got it hooked up I turned on the AC power on the Delta Pro and the Ultra started charging but it tried to pull too much from the Delta Pro and the Delta Pro overloaded. Tried a couple times and each time it overloaded. Later i realized i hadn't upgraded the firmware on the Ultra which was 1.x something and the new firmware was 5.x, so i upgraded and tried the experiment again. This time when i turned on the AC the Ultra errored out with an error of 258. Thankfully it still works fine once i disconnected it. Anyone know what this error is? If you can connect a 30amp 120v generator port to the Power Input port I would think you could connect to the Delta pro's 30amp outport port, but maybe not. What do you all think?
Specs for Power Input\Output port from Ultra user manual:
Power Input/Output | 100-120~30A; 200-240V~30A, 50/60Hz |
