sustainableengineer
I have a solar generator configuration using the ECOFlow Delta Pros; I would appreciate a comment. I have a write-up and diagram that I will attach.
Thanks in advance for your help with this.
Here is a summary of my design and questions.
ECOFlOW DELTA PRO SOLAR EAST / WEST DESIGN
Design specification for review.
ECOFlow Delta Pro(s)
2 ECOFlow Delta Pros with battery extension
Combiner Cable box for 240 VAC output
120VAC Charging Input
D.C. Solar charging input
200 Amp Sub Panel
Solar
12 total 300W panels, 6 for each ECOFlow Delta Pro A and B See diagram
ECOFlow A and array A
ECOFlow has an array of two strings on an east-west roof, with three series panels in parallel with another string of three panels.
32.5 vdc x 3 = 97.5 vdc
9.85 dc amps x 2 = 19.7 dc amps
Total over-paneled wattage of 1900 watts
See diagram
ECOFlow B and Array B
ECOFlow has an array of two strings on an East / West roof, with three series panels in parallel with another string of three panels.
See diagram
Questions:
In an ECOFlow combined configuration, how do the batteries from each balance out?
Can the A.C. output be fed back into the A.C. charge input?
Will this help to balance the battery charge level between the two units?
The series/parallel combined solar array configuration ensures maximum solar power for the inputs of the ECOFlows.
See diagram
200 Amp Sub Panel
Solar
See diagram
See diagram
Questions:
See diagram
