Ecoflow shp2 - generator & grid at same time?
mcdonsco
Portland Oregon
I have two ecoflow shp2's installed each has a single delta pro ultra connected. I also have multiple EV's, one being an f150 with the onboard generator.
I will have solar dump all excess into the truck and want to then use that as a "generator" to feed the deltas as needed throughout day & night. I tired the ecoflow generator adapter, but apparently that only works with ecoflow generators (designed to NOT work...🤬).
I'm thinking of having electrician wire a single generator port into the system wired directly to power the two panels, but can they use that as the same time as still being on the grid? Or would it have to be one or the other not both? We will pull from the grid in the winter / nights, hence the question.
Thanks!
