Hello All,
Looking for opinions on a EcoFlow Delta Pro Ultra w/ Smart Home Panel 2 or Buetti EP800 vs. a more DIY EG4 6000XP w/ Rack Mount Batteries...
Background:
I have been getting my feet wet with solar/battery backup systems on a small 12v scale for several years now. I have a system at my off-grid cabin with a GoPower IC2000 and 12v 170ah LFP diy battery. At home, I have a MPP 1012 AIO with a 300AH Rebel LFP battery running my Internet and computer rack.
I got permission from the "finance committee" to do a larger system at home. ? We lose power probably 4-5 times a year for significant time and at least once every few years is for several days to a week or more. We do have a backup generator that will run all of the essentials (just maybe not all at the same time) and that is fine for us. However, it is not automatic and my wife is not comfortable with the procedure of hooking it up. (This is amplified when the power goes out at night in a snow storm)
Solution:
Since I'm familiar with building systems from components, I had planned to put together an initial EG4 system with the 6000XP and (2) EG4 rack mount batteries. (knowing I could add on as needed) However, my wife has not been happy with my "experimenting/learning" with our existing 12v system and told me she would prefer a more "commercial" easy for her to understand/manage system (even though I told her it would be more expensive).
Sooo... that got me looking at the Bluetti EP800 and the upcoming Ecoflow Delta Pro Ultimate/Smart Home Panel 2 solutions... There is no firm pricing on the DPU/SHP2 yet. However, I'm gestimating that both solutions will run about $4000 - $6000 more for similar battery capacity as the EG4 system. Both setups will require me hiring an electrician to do the wiring for the associated critical circuit panels and wiring (I don't have physical room next to our main panel. So any system will have to be installed about 30' away on the other side of our basement.
Note: Solar panel connections will come later. Initially, just looking at an automatic battery backup system.
Pros:
Concerns:
Appreciate any thoughts people may have on the subject!
Thanks,
JAS
Background:
Solution:
Pros:
- Both Bluetti and EcoFlow systems have a really nice compact form factor that are unobtrusive and or more easily mobile if necessary. Apps seem pretty nice.
- EcoFlow system has the best control over individual circuits and battery management
- EG4 system is much cheaper. Plug and play. All components can be swapped out and/or bypassed easily. Upgradeability is the most flexible and less costly. Even if company or product goes out of support, different vendor/products can be relatively easily swapped in place.
Concerns:
- Bluetti - Reputation for support is not great. Costlier to add capacity down the road. If Inverter goes down, the batteries are unusable with any other Inverter. What happens to support after they move on to a newer product? Or what if they go out of business?
- EcoFlow - Reputation for support is better. Costlier to add capacity down the road. Same problem as Bluetti if Inverter goes down. What happens if something goes screwy with the SHP2? Is it possible that my critical circuits could go down without being able to bypass? What happens to support after they move on to a newer product? (like from the SHP to the SHP2) Or what if they go out of business?
- EG4 - Takes up quite a bit more space. Requires wall mounting (and preferred fireproofing). In general more work to connect up. More intimidating to look at for my wife and understand what to do in an emergency. (Although, I think the "kill" switch on the 6000XP makes for a nice addition)
Thanks,
JAS
