First a quick background... We lose power maybe 2-3 times a year for a max of about 2-3hrs each time(mainly due to bad weather). I have a 5.5kw gas gen that we used a few times via extension cords... Time to upgrade! I'd like to keep the gen (I sometimes use it in the yard) and go home battery (no plans for solar). Like most everyone, with the Ecoflow Ultra popping up everywhere it's caught my eye. I've been back and forth between DIY and Pre-made (Ecoflow). Main things I'd like to power are as follows (specs listed, rounded up)
1) Oil boiler (circular pump, motor, etc) 15amps (provides heat/hot water)
2) Kitchen fridge - 7amps
3) Garage Fridge - 3amps
4) Garage Freezer - 2amps
5) Sump Pump (1/3hp) - 6amps (not really worried about this since it has its own 12v/2k auto xfer inverter and 12v 100ah 2x batteries)
Obviously depending on the weather some won't need power (garage is not insulated). Summer we can use a fan or stay in the basement since it's below ground and the temp year round is between 64F-70F. So with all that said, I'd like the option of covering critical loads (weather-wise) and basic lighting. My magic number is about 8000watts running, so I based my numbers around that(taking into account the 80% useable wattage)... Ecoflow Ultra with a second battery comes in about $10k for 12k capacity and 7.2k running watts. Or (either) Aims Power 8k inverter (or Victron 48v/8000 inverter multi-plus 2) paired with EG4 LiFepo4 48v/100ah server batteries for about $7500 (fuses/wires/misc items included). Both would require me to install a xfer switch regardless. Only real difference is with the Ecoflow I can charge it off my standard 120v outlet where as the DIY I'll need to install a 230v outlet. I don't think I would ever expand much beyond either option (capacity wise). What do you guys recommend? Am I aiming to high for running watts? My home is about 1900sqft. According to my electrical bill we use between 600kwh (winter) to 1200kwh (summer/ no central air, only window AC's) a month. I'd appreciate any input on this, thanks in advance.
