Hi what solar panels do I need for this setup.
It say in a text to !
check your PV voltage carefully and see if it works with this inverter(VMP 55-450v )
Thanks for any help
EDECOA 6200W 6.2KW Hybrid Inverter 48V 240V Off Grid MPPT 110A PV 55-450VDC | eBay
This inverter is not just your ordinary inverter! Power Almost Everything For the output power, we've got you covered. With a maximum power output of 6200W, you'll never run out of juice. OFF grid: the inverter does not feed power into the grid.
www.ebay.co.uk
