I've been doing a lot of research into solar systems in preparation for installing one, hopefully in the near future. I am impressed with the 18KPV, but I have one question I can't find the answer to in the manual. The EG4 6500s allow you to set a minimum battery SOC value, at which it will switch to Grid power and recharge the batteries. I cannot find the same parameter settings in the 18KPV manual. You can set a minimum SOC which will turn on a generator to charge the batteries and you can set specific times of the day to charge the batteries from the grid, but I don't see how to set the batteries to charge from the grid when they reach an SOC setpoint. Has anyone found and/or is using that capability? Thanks.
