RebelWithoutACausey
Hey gang,
I have installed the electrical components for my school bus build, and while im fairly electrically literate, im playing with a far bigger system than anything im used to installing. That said, I’m scratching my head here.
My battery bank consists of two EG4 Lifepower 4 24v batteries, currently being charged by the victron MPPT 150/100, with a solar array of 6 panels wired 2S3P. The ither charging method is through the Victron Quattro, but I haven't programmed it yet and have not used it at this time. Parked at the shop here, there is no shade and we have had 3 clear, sunny days since I flipped the switch.
One battery displays a full SOC (4 of 4 LEDs) and isolated at the terminals, shows 26.2v. The second battery displays 3 of 4 LEDs, and the terminals show 28.3v. Both of them are connected to the system with equal length 4/0 cables into the victron lynx power in.
The reported SOC of the batteries vs the voltages at the terminals does not make any sense to me.
Further, it appears that they aren't accepting nearly as fast of a charge as I expected. My array is rated for 2400 watts, and while I didn't expect to get the full rated output, from the victron app it seemed to be charging at around 1100 watts. I set the parameters in the victron app per the suggested figures in the manual, maybe there is something else im missing? At the current rate, a full day of sun wont be enough to recharge the batteries fully if I deplete them through the night.
Im confused, so any resources or advice on how to get all this new expensive equipment to play nice together would be GREATLY appreciated.
Thanks!
Thanks!
