kfly
- Oct 28, 2022
- 6
As per page 52 in the EG4-3000EHV-48-V2-Manual there should be a way to see the Battery capacity in Amp Hours. #6 below.
if I cycle through all the screens there is no screen with a battery AH or amp hours info.
I have 2 EG4-Lifepower4 48v V2 batteries and the "li" icon is on indicating there is good battery comms.
Guess main question is how do you know the EG4-3K is seeing the second battery. If you unplug the comms cable to the second battery you don't get Warning code (19) like you do if you unplug the comms cable to the main battery.
(current dip switch is battery 0 (D-D-D-D) and battery 1 (U-D-D-D)
Everything seems to work just fine. Would like like some kind of confermation that the inverter is seeing the second battery via comms cable.
