Why would the EG4 all of a sudden start reading .31 volts lower than the actual? This is a problem as the actual charging results have been .31 higher than the batteries max recommended amount. Note: As the bank is comprised of (12) 12v 220ah units wired in 3 series sets of 4 batteries, making the actual over voltage per battery of .07v over the max. Would this cause and permanent damage or any damage at all? Being winter and my solar output is less, Im unable to tell at this point. When I first setup the system I monitored the voltage for days to verify settings and results, and as of a few months ago that was still the case as I do perform spot checks. This is new, and hope I have not damaged my batteries in the interim. Anyone else experienced this? Or am I missing something?
