EG4 LLv2 and rack wiring question
jcollinsks
West Virginia
I saw in Will's video that you need to flip the negative bus bar to get the battery to inverter connection on the bottom so it drains the batteries equally. Is that still a thing with the new versions?
I just removed a little of the the heat shrink and used the handily sized holes at top and bottom. This made a better connection for doing 2 lugs (front and back vs stacked) i say this with stacked connections in the same photo.
