kaseywantssolar
- Oct 16, 2021
- 13
I wanted a non-invasive cheap clamp meter to measure the current output from my panels. I found this is aliexpress for $10 bucks and while it’s no precision device (min resolution = 300mA!), it does seem to work quite well AND the sensor hole is big enough for a MC4 connector to pass thru. Less convenient than a DC clamp meter but cheaper so i get to buy a few more beers instead.
https://www.aliexpress.com/item/32945986601.html
I bet there must be similar in Amazon or ebay too.
If you want higher resolution it says to wrap the wire around the sensor and divide the readings by the # of turns. So 30A reading with 3 turns = 10A irl. I didnt need this so didnt try it.
Just a note that it seems to be slightly more accurate in one direction vs the other. Theres some more info on this meter here but it just aint that complicated lol… http://www.wooliis.com/Enproducts_view.aspx?ID=71
Hth
Hth
