I've done some searching and it appears the consensus is that disconnecting batteries while under load = arc. Makes sense. I would need to remove the load by shutting off the main AC breaker feed from the inverter, then inverter off.
I'm trying to come up with a manual emergency disconnect solution in the exceptionally rare catastrophic event and I have to physically roll my 24v Lifepo4 ESS/battery bank outside to vent.
assuming no load.... are these 175a rated Andersen style DC connectors the solution?
