Emergency battery disconnect
MezzBatt
Ok. general question here, obviously the current shunt is directly connected to the battery positive term but I have a high rated disconnect switch I intend to use as an emergency battery cut off placed at the front of the electrics tray and immediately accessible upon entry. Is it ok to interrupt this leg of the power cable before it reaches the class T fuse or does the fuse go in CCT before the switch and if the latter what about the connection from the SCC main fuse..??? Just trying to get this functionally correct before I start crimping lugs on....
It's with the use of an Electrodacus BMS, do I need to be aware of different rated shunts in respect of pos/neg connection...???
