Dear all,
I got a EPEVER 4415 Xtra for a small stand alone system with a 24v 280AH LiFePo.
Since its my first solar system I am currently learning. Also, please bear with me, english is not my first language.
I read a couple of articles here and I just want you to check my settings and to let me know, if I understand some settings correctly.
My LiFePo4 batterie is a DIY build with a JK BMS.
As you can see I set the Charging limit voltage lover then the Cell OverVoltage protection from the BMS, reason as to why it is 0.1V lower then in the BMS is, there was a hint in the manual that the 4415 is wiggleing +- 0.2V around the current voltage setting. I might change the Charge Limit Voltage to 28,6 later.....
As you can see the BMS has very moderate settings when it comes to the LiFePo battery, to increase the lifetime.
After configuring the EPEVER 4415 like shown in the first image I got some doubts about the Boost Charge setting.
So I changed it to this, which is the current setting:
Thanks to Mr @Browneye and his explanation within the Thread:https://diysolarforum.com/threads/s...4-settings-in-epever-tracer.17785/post-706182 I got the following understanding of the Boost Charge setting:
The MPPT will charge the battery with its maximum, till I get to 28.6V and then will continue to do so for the next 75 Minutes according to the Boost Duration time, correct. And as soon as I get to the Charging limit voltage of 28.7V, the MPPT will stop charging the battery, correct?
I set 75 Minutes, because I read in a different thread I should add 30 Minutes per 100AH, but I have also seen some suggestion to set it to 10 Minutes.
So, from my understanding, that should work fine, pretty much, or did I miss something here?
On remark here: I dont know why, but the EPEVER keeps to reduce the 'Series Number' from 8 to 6 when I reconnect to the EPEVER and Read the values from the MPPT. I always set it to 8 and press Update.......
kind regards,
Andreas
kind regards,
Andreas
