D
Deleted member 783
Guest
No matter how many times I change my charge controller to gel, it switches back to sealed as soon as I close the app on my phone. Does anyone know how to make it stick?
@ Lost In The Desert is there a phone app for epever CCs? I have two of the 4215bn in use and that would be great. Is the app only for specific models and I’m guessing but is it thru the BT module?
Yup, pick up the bluetooth module for about $28 USD and download the phone app from their website. You can't use the MT-50 and the bluetooth dongle at the same time, fyi.
I have a Tracer AN and use an RS-485 cable. The PC interface seems to work okay at storing the settings. I have only changed them a couple of times, but are set for LiFePo4 and seem to stay put.Yup, pick up the bluetooth module for about $28 USD and download the phone app from their website. You can't use the MT-50 and the bluetooth dongle at the same time, fyi.
In the phone app is there a Save or Update button? I don't recall what the PC program has for an Update button.
How do you like the App, I was considering a victron because of the App and because Will is always raving about how easy it is to configure, but I'm always looking to save a buck and I've heard the Epever units are decent quality.
I initially had an issue with the PC program because I had missed a step in the communication setup. Are you able to read the data in from the charger, with the phone app? If you can't read the setting in from the charge controller then correcting that problem would need to be done.Yes, it has a "send" button. It seems as if the app has an error. Even when it's set on "sealed" on the app, the MT-50 will still display "gel" when I plug it in.
Currently I have a grid tie system without standby power. I do have a generator. I just purchased some batteries, an inverter, a manual switch-over subpanel, and I am starting to set that up so the generator can power the subpanel and charge the batteries. Also the batteries can be solar charged with some panels that are not my grid tie panels. That standby power project is under construction but still fairly early in the game. I have my batteries charging from the solar but the subpanel is not yet tied in.@DThames are you by any chance running a generator? (unrelated question)
