crccrkc1995
- Mar 5, 2022
- 28
I have 4 200w 12v panels of solar on my RV roof, two each in parallel then in seties for a 24v system. I have a 50amp Epever MPPT, and a 2000w Sun Gold Power inverter charger. I have two SOK, 206ah batteries in series for 24v. I am trying to set the parameters in the MPPT for the SOK batteries. I have the battery ah set at 412ah. I understand I have to double the parameters listed for a 12v battery but when I try to do that I get a "Para. Error" on the remote display. I read about doing the setup in the "proper sequence" but I can't find the sequence anywhere. I have all green lights and smily faces on the MT50 but I know the parameters aren't what they need to be. I also occasionally get a continuous beep from my Inverter charger that started today. I assume this is due to the wrong parameter settings. I have turned my system off until I can get get some answers. Any help would be greatly appreciated. Thank you!
