Hello,
I was thinking of creating a simple 12V 250W solar panel with an inverter to 120V or 230V AC to charge cars like the Volkswagen e-up at a very slow rate, maybe like add a 1kWh of charge in a sunny day. I'm talking without any battery in between, just straight from solar.
However this EV like many others won't charge at currents below 5A so if the math is correct considering the input from the solar and that the battery in the car is 400V+ that maximum current the built-in charger will be able to output is less than 1A so it won't work at all.
The questions are:
1) why do EVs manufactures care if you charge at a such incredible low current/wattage? Is there some kind of technical limitation I don't see?
2) is there a way to overcome this while keeping the panel small and the system overall cheap?
I know I could install a bigger solar panel system on the roof directly but I'm talking about a hobby here, I'm not trying to create a charging station at home. I already know I'll probably never "break even" even with just a 100W panel.
The questions are:
