I have an EG4 18kvp and a PowerPro battery. I am currently using it as an off-grid generator only, no solar yet. When I recharge the battery with my 6000 running watts, 7500 peak 240v 30amp Champion generator hooked into the 18kvp generator inputs, the charge rate is typically only about 3500 watts, but it's also been as low as 1100 watts and as high as 6000. Generator functioning normally in all cases. And this wasn't just for a few minutes or something, it was for as long as I ran the generator, hours. Today it was charging at 6000 watts for a few hours, I shut off the generator, turned it back on 30 minutes later and it was 3500 watts. Yesterday it was 1100 watts every time I ran it. I would love for it to be 6000 watts all of the time, any ideas what is causing the variation? I saw on another post that the generator charge current limit setting should not be the generator Amps but rather the charge current limit of the batteries? It's currently set at 30 amps, so I should change it to 100amps (recommend charge current limit for PowerPro)?
Even if that setting is the main culprit, the fact that it's done 900 watts and 6000 watts should suggest something is not working properly, because it should be the same every time within a small margin based on the 30amp charge current limit setting. I am only using 3 wires from the generator, +,-, neutral, no ground and the generator is not grounded, not sure if that's a problem?
Any ideas what's causing this and how to get 6000 watts charge consistently?
Follow-up question, I have a rack of LifePower4s I plan to add to the mix, the recommended charge current on those is only 50amps, since it's a rack of six, is it 300amps? And do I add the 160 of the PowerPro to that for a total charge current limit of 460amps?
Thanks!
Thanks!
