Hi,
I'm trying to connect with the JK-BMS-Monitor (as i want to upload a more recent firmware) my JKBMS inverter.
I've this version :
* Vendor ID: JK_PB2A16S20P
* Serial Number: 31213490063
* Hardware Ver:: V15.XA
* Software Ver:: V15.05
* MPT L Version: [001] [001]
* Version: V4.19.6
In the device manager of windows, i saw my device usb to rs485 as "USB Serial Port (COM3)"
So i configured as Device ID: 1 & Port Name: COM3 on JK-BMS-Monitor
When i click to connect , it's say "Comm. Status: Connected" but the interface is nearly empty ( no battery status, no voltage, setting and Control are in grey ,not able to push a new firmware , ... )
My usb to rs485 is working as i already used to connect on other device and as it's a rj45 connector, it's not possible to be a wiring issue.
Of course, i've try with other network cable : same issue
i've try to 2 different version of JK-BMS-Monitor and on 2 different windows machine : same issue
I've try many thing but what it's strange it's when i look on terminate of JK-BMS-Monitor :
* if i set the Dial switch position on JKBMS to use the address 1 : (the normal configuration)
get sending log ( one line every 2 seconds )
( but don't get receiving data)
* If i change the Dial switch position on JKBMS to use the address 0 :
i still can't connect but i see 16 table of device in JK-BMS-Monitor and log are completely different :
get lot of receiving log ( but sending log remain empty ) :
if someone can help. i will appreciate
I've this version :
* Version: V4.19.6
Code:
[00:40:45,185] 01 10 16 1C 00 01 02 00 00 D3 CD
[00:40:47,300] 01 10 16 1E 00 01 02 00 00 D2 2F
[00:40:49,310] 01 10 16 1C 00 01 02 00 00 D3 CD
[00:40:51,323] 01 10 16 1E 00 01 02 00 00 D2 2F
[00:40:53,748] 01 10 16 20 00 01 02 00 00 D6 F1
[00:40:54,557] 01 10 16 20 00 01 02 00 00 D6 F1
[00:40:55,382] 01 10 16 20 00 01 02 00 00 D6 F1
[00:40:56,184] 01 10 16 20 00 01 02 00 00 D6 F1
[00:40:57,003] 01 10 16 20 00 01 02 00 00 D6 F1
[00:40:57,810] 01 10 16 20 00 01 02 00 00 D6 F1
[00:40:58,627] 01 10 16 20 00 01 02 00 00 D6 F1
[00:40:59,436] 01 10 16 20 00 01 02 00 00 D6 F1
[00:41:00,252] 01 10 16 20 00 01 02 00 00 D6 F1
[00:41:01,064] 01 10 16 20 00 01 02 00 00 D6 F1
[00:41:01,868] 01 10 16 20 00 01 02 00 00 D6 F1
[00:41:02,687] 01 10 16 20 00 01 02 00 00 D6 F1
[00:41:03,501] 01 10 16 20 00 01 02 00 00 D6 F1
[00:41:04,312] 01 10 16 20 00 01 02 00 00 D6 F1
[00:41:05,126] 01 10 16 20 00 01 02 00 00 D6 F1
[00:41:05,934] 01 10 16 20 00 01 02 00 00 D6 F1
Code:
[00:43:25,416] 00 55 95 E1 B3 FF 09 5E C0 5E C0 5E C0 5E C0 5E C0 DE 5E C0 DE DE DE 5E DE 5E C0 5E C0 5E C0 DE FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
[00:43:25,452] FF FF FF FF FF FF FF FF FF FF 01 00 FF 05 DE DF E9 FD 8B FF 89 FF 6B FF 67 FF 4D FF 3B FF 17 FF F5 EB 01 FF 17 FF 1F FF 33 FF 65 FF 6D FF 2B FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 61 FF FF FF FF 5B 18 FF FF FF FF FF FF FF FF FF 77 71 FF FF FF FF FF FF FF B5 AF 8D FF FF 7F C7 FF FF FF FF FF FD FF FF FF 37 FF FF FF C3 69 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 01 FD FF FF FF 6F 7E FF FF FF E1 2E 60 FD FF FF FF 6F DD FF FF FD FD FD F9 F3 FF FF DF 6F FF FF FF FF FF 61 75 73 5F 7E 7E 9D DA 2F FB FF FF FF 57 7F FF FF FF FF FF FF FF FF FF FF FF FF FF 03 00 40 11 78 7F 9F 7C FF FF EB FF DF D3 BF FF FD F5 00
[00:43:25,854] 00 55 95 E1 D3 FF 93 DF FF FF F7 E9 FF FF BB E9 FF FF 2F DF FF FF 6B DF FF FF EB FF FF FF 57 DF FF FF CF E9 FF FF 43 DF FF FF 6B DF FF FF 1F BD FF AF 4F FF F9 FF FF FF 87 FF FF FF 7F E5 F9 FF A7 FD FF FF 87 FF FF FF F5 FF FF FF 5F 7C FF 87 BF FF 4F FB FF FF 87 BF FF 4F FB FF FF 8F 01 00 00 4C 00 00 21 FF FF BF F9 FF FF DF FF FF FF FF FF FF FF FF FF FF FF FD FF FF FF 7F C7 FF D3 FF FF 8F 7A FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF F7 FF FF FF 3F 39 BA DF FF 87 9B CF 03 00 00 00 60 0B 7F BF FF FF FF 2B FF DF D3 C3 FF FD 37 53 00
[00:43:26,220] 00 7F 37 F7 FB FD FB FF FF 53 00
[00:43:26,622] 00 BF 37 F7 FB FD FB FF FF 7B 00
[00:43:27,018] 00 7E 37 F7 FB FD FB FF FF 61 00
[00:43:27,420] 00 DF 37 F7 FB FD FB FF FF 2D 00
[00:43:27,822] 00 7D 37 F7 FB FD FB FF FF 37 00
[00:43:28,218] 00 BE 37 F7 FB FD FB FF FF 1F 00
[00:43:28,620] 00 7C 37 F7 FB FD FB FF FF 05 00
[00:43:29,022] 00 EF 37 F7 FB FD FB FF FF 87 00
[00:43:29,418] 00 7B 37 F7 FB FD FB FF FF 9D 00
[00:43:29,820] 00 BD 37 F7 FB FD FB FF FF B5 00
[00:43:30,222] 00 7A 37 F7 FB FD FB FF FF AF 00
[00:43:30,619] 00 DE 37 F7 FB FD FB FF FF E3 00
[00:43:31,020] 00 79 37 F7 FB FD FB FF FF F9 00
[00:43:31,422] 00 BC 37 F7 FB FD FB FF FF D1 00
[00:43:31,818] 00 78 37 F7 FB FD FB FF FF CB 00
[00:43:32,221] 00 55 95 E1 B3 FF 09 5E C0 5E C0 DE 5E C0 5E C0 DE DE 5E 5E C0 DE 5E DE 5E C0 DE 5E C0 DE FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
[00:43:32,256] FF 01 00 FF 05 DE DF E9 FD 8B FF 89 FF 6B FF 67 FF 4D FF 3B FF 17 FF F5 EB 01 FF 17 FF 1F FF 33 FF 65 FF 6D FF 2B FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 61 FF FF FF FF 55 18 FF FF FF FF FF FF FF FF FF 77 71 FF FF FF FF FF FF FF B5 AF 8D FF FF 7F C7 FF FF FF FF FF FD FF FF FF 37 FF FF FF B5 69 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 01 FD FF FF FF 6F 7E FF FF FF E1 2E 60 FD FF FF FF 6F DD FF FF FD FD FD F9 F3 FF FF 57 6F FF FF FF FF FF 61 75 73 5F 7E BD 9D DA 2F FB FF FF FF 57 7F FF FF FF FF FF FF FF FF FF FF FF FF FF 03 00 40 11 78 7F 9F 7C FF FF 3B FF DF D3 BF FF FD F5 00
[00:43:32,652] 00 55 95 E1 D3 FF 93 DF FF FF F7 E9 FF FF BB E9 FF FF 2F DF FF FF 6B DF FF FF EB FF FF FF 57 DF FF FF CF E9 FF FF 43 DF FF FF 6B DF FF FF 1F BD FF AF 4F FF F9 FF FF FF 87 FF FF FF 7F E5 F9 FF A7 FD FF FF 87 FF FF FF F5 FF FF FF 5F 7C FF 87 BF FF 4F FB FF FF 87 BF FF 4F FB FF FF 8F 01 00 00 4C 00 00 21 FF FF BF F9 FF FF DF FF FF FF FF FF FF FF FF FF FF FF FD FF FF FF 7F C7 FF D3 FF FF 8F 7A FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF F7 FF FF FF 3F 39 BA DF FF 87 9B CF 03 00 00 00 60 0B 7F BF FF FF FF 2B FF DF D3 C3 FF FD 37 53 00
[00:43:33,018] 00 7F 37 F7 FB FD FB FF FF 53 00
[00:43:33,420] 00 BF 37 F7 FB FD FB FF FF 7B 00
[00:43:33,822] 00 7E 37 F7 FB FD FB FF FF 61 00
[00:43:34,219] 00 DF 37 F7 FB FD FB FF FF 2D 00
[00:43:34,620] 00 7D 37 F7 FB FD FB FF FF 37 00
[00:43:35,022] 00 BE 37 F7 FB FD FB FF FF 1F 00
[00:43:35,419] 00 7C 37 F7 FB FD FB FF FF 05 00
[00:43:35,820] 00 EF 37 F7 FB FD FB FF FF 87 00
[00:43:36,222] 00 7B 37 F7 FB FD FB FF FF 9D 00
[00:43:36,619] 00 BD 37 F7 FB FD FB FF FF B5 00
[00:43:37,020] 00 7A 37 F7 FB FD FB FF FF AF 00
[00:43:37,422] 00 DE 37 F7 FB FD FB FF FF E3 00
[00:43:37,818] 00 79 37 F7 FB FD FB FF FF F9 00
[00:43:38,220] 00 BC 37 F7 FB FD FB FF FF D1 00
[00:43:38,622] 00 78 37 F7 FB FD FB FF FF CB 00
[00:43:39,018] 00 55 95 E1 B3 FF 05 5E C0 5E C0 DE 5E E0 03 DE DE DE DE DE 5E 5E C0 5E C0 5E C0 5E C0 DE FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
[00:43:39,054] FF FF FF FF 01 00 FF 05 DE DF E9 FD 8B FF 89 FF 6B FF 67 FF 4D FF 3B FF 17 FF F5 EB 01 FF 17 FF 1F FF 33 FF 65 FF 6D FF 2B FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 61 FF FF FF FF 57 18 FF FF FF FF FF FF FF FF FF 77 71 FF FF FF FF FF FF FF B5 AF 8D FF FF 7F C7 FF FF FF FF FF FD FF FF FF 37 FF FF FF A9 69 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 01 FD FF FF FF 6F 7E FF FF FF E1 2E 60 FD FF FF FF 6F DD FF FF FD FD FD F9 F3 FF FF CF BB FF FF FF FF FF FF 61 75 73 5F 7E B7 4A EF A1 FF FF FF FF 57 7F FF FF FF FF FF FF FF FF FF FF FF FF FF 03 00 40 11 78 7F 9F 7C FF FF 9D DF D3 BF FF FD F5 00
[00:43:39,450] 00 55 95 E1 D3 FF 93 DF FF FF F7 E9 FF FF BB E9 FF FF 2F DF FF FF 6B DF FF FF EB FF FF FF 57 DF FF FF CF E9 FF FF 43 DF FF FF 6B DF FF FF 1F BD FF AF 4F FF F9 FF FF FF 87 FF FF FF 7F E5 F9 FF A7 FD FF FF 87 FF FF FF F5 FF FF FF 5F 7C FF 87 BF FF 4F FB FF FF 87 BF FF 4F FB FF FF 8F 01 00 00 4C 00 00 21 FF FF BF F9 FF FF DF FF FF FF FF FF FF FF FF FF FF FF FD FF FF FF 7F C7 FF D3 FF FF 8F 7A FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF F7 FF FF FF 3F 39 BA DF FF 87 9B CF 03 00 00 00 60 0B 7F BF FF FF FF 2B FF DF D3 C3 FF FD 37 53 00
[00:43:39,822] 00 7F 37 F7 FB FD FB FF FF 53 00
[00:43:40,218] 00 BF 37 F7 FB FD FB FF FF 7B 00
[00:43:40,620] 00 7E 37 F7 FB FD FB FF FF 61 00
[00:43:41,023] 00 DF 37 F7 FB FD FB FF FF 2D 00
[00:43:41,418] 00 7D 37 F7 FB FD FB FF FF 37 00
[00:43:41,821] 00 BE 37 F7 FB FD FB FF FF 1F 00
[00:43:42,222] 00 7C 37 F7 FB FD FB FF FF 05 00
[00:43:42,618] 00 EF 37 F7 FB FD FB FF FF 87 00
[00:43:43,020] 00 7B 37 F7 FB FD FB FF FF 9D 00
[00:43:43,423] 00 BD 37 F7 FB FD FB FF FF B5 00
[00:43:43,818] 00 7A 37 F7 FB FD FB FF FF AF 00
[00:43:44,220] 00 DE 37 F7 FB FD FB FF FF E3 00
[00:43:44,622] 00 79 37 F7 FB FD FB FF FF F9 00
