Hello I have a 16s battery pack made from used Winston Thunder Sky 300ah lifepo4 cells. In the two months sitting outside on deck of my boat some terminals corroded (the worse is pictured). As you can see the negative terminal is copper and positive along with the nuts are aluminum. In a marine environment dissimilar metals will cause galvanic corrosion and its avoided by grounding the system to sacrificial zinc anodes. I can't ground the pack directly to my grounding system and I don't know if grounding to the output of the bms will be sufficient or even a good idea? Currently the 48v is ground isolated from the 110vac/12vdc. Does anyone have experience with this? I have thought about adding a zinc directly to my battery.
