Sgt.Pepper
- Oct 16, 2020
- 4
Hi All,
I have a small off grid cabin that I'm powering with a Renogy Lycan 5000. For now I'm using the outlets on the Lycan, but it will be tied into a sub panel that will power the cabin.
While I wait to get the ground mount for my solar array installed, I'm going to be charing the Lycan with my Honda eu3000is. And eventually, will be using both when circumstances require it. Unfortunately, the AC charging cable that came with the Lycan is about 10ft long and prevents me from getting the generator far enough away from the cabin to be safe. I'm now searching to find a cable that will fit my needs and am coming up empty handed. The Lycan charges via an IEC C19 to NEMA 5-20P cable and trying to find a 50ft+ outdoor rated version of that cable is proving impossible.
My eu3000is has both a 20 amp circuit and a 30 (really 23.3) amp circuit. I originally considered using just the 20 amp and finding the right cable, but alas here we are. Now I'm considering using the the 30 amp circuit with a l5-30p cable.
Here's the tricky part through, I still can't find the right cable (e.g. L5-30p to c19). So I'm thinking about using a l5-30p to l5-30r cable to a generator inlet box. Something like this: https://conntekisi.com/30-amp-125v-l5-30-power-inlet-box-cable-combos Then from the inlet box, I'd wire in a 20 amp 5-20r outlet to plug the lycan into. The Lycan has 20 amp breaker for AC input, so I'd never pull the full 30 (23.3) amps.
I'm starting to wonder if I'm making this way too complex.
Any thoughts on how I should do this?
