charliefleet
- Sep 15, 2022
- 17
Is it possible to simply glue a new semi-rigid panel on top of an old failed panel, assuming they are same size.
The old panel is completely down with copious adhesive and sealed around the edges. It's going to be a complete pain to remove.... assume they would use a cheese-wire? And cut it off underneath.
The roof is completely flat with no ridges.
So how secure would a new panel glued on top be? I'm thinking it might alwo provide some degree of insulation... the old panel perhaps failed due to heat, lack of cooling?
