Goodwe parallel problem FIXED
Neil H
Swindon UK
I have s problem with parallel connecting two Goodwe GW6000D-ES-20
I have set up the master and slave
(the master works fine on its own)
I conect the coms cable between the two invertors and they seem to be taking to each other ok
the problem I'm having is that as soon as I conect them I lose the conection to the smart meter
My guess is that there is a "termination" setting. One of the devices (inverter master, inverter slave, smart meter) has to be in the middle. That device has to NOT have termination resistor enabled.
Or an address conflict. Maybe the slave and smart meter are set to the same device number.
