WorldwideDave
Just looking at the way, my existing home has its main panel and disconnects and power meter, I noticed it has a ground wire coming out of the main load center into a very large copper rod that is going down into the Earth. It is probably half inch or 5/8 diameter, copper.
I noticed on the front of the panel on the outside near the power meter there is also a green solid core ground wire that runs up to the roof. I believe it connects to a combination of devices, including our old Bell, telephone landline system, coax cable from, a cable TV installation, possibly from a DIRECTV dish on our roof, and definitely from our fiber optic cable Internet line.
We also have a sub panel. I’m fairly certain that does not connect to any copper pipe. I believe the ground wire probably if it has one goes back to the main load center and connect to the ground bus over there. I can take the cover off and inspect to be sure.
I guess my question is… If we have one large single-story house with two panels in it, why is the sub panel not supposed to go to an earth grounding rod?
I watched some videos yesterday explaining how bonding and grid tie inverters work… Now I’m trying to understand how non-solar applications work.
