Light24bulbs
- May 29, 2020
- 4
I've just installed a growWatt 3000 LVM. This is replacing my many individual boxes.
One big issue with my setup, however, is that my shore power is pretty limited. It's on a long run and it's only a 20 amp circuit. I can't really pull more than 1,500 or tops 1,800 watts out of it before voltage drop becomes excessive.
Most of the time, that's no trouble, but once in a while I'm doing too many things at once. What I really need is for the system to switch back over to battery power in that case. It's even worse if the unit is also charging the battery at the same time. So far I've simply set the charge current very low to help.
Now, if the shore voltage gets pulled TOO low, it will switch back to battery momentary, and then it will cycle between shore and battery continuously about once a second as it repeatedly pulls the shore power too far down. This sucks and is going to wear something out.
Does anyone know of a way to accomplish a programmable limit? Is this something the MPP all-in-ones can do but the growatt can't? I would gladly switch if so, I can still return this.
Thank you
Thank you
