Hi. I’m new here and would like to know if anyone could help here…
I have a solar setup with 6x505W solar panels and Growatt MIN 3000TL-XH. I installed it with 2 modules of Growatt ARK 2.5H-A1 HV and a BMS. (Single phase)
This was a year ago and the setup worked fine.
Now I decided to add 2 more battery modules to my setup so I can have more electrical independence.
The problem is that I'm only getting around 6.5kW of usable battery for the 100->10% cycle.
My current battery capacity is 10.24kW. I should get at least 8.5kW for the same 100->10%.
If I check the battery voltage the modules seem fine, I have around 212V with the 4 modules.
Anyone have an idea what the problem might be and how to fix it?
Thank you.
Thank you.
