Growatt MPPT MC4 connectors
VinceNY
Baldwin, NY
Growatt MC4 Connectors
Great forum! So I recently installed the Growatt 6kW Grid-Tie Inverter | MIN 6000TL-X purchased from SignatureSolar.com The install was successful, but I had trouble connecting the MC4’s. The one on the left is what came with the Growatt Inverter and the one on the right is what I received from Amazon, crimp on connectors and the breaker box . I wanted to connect a DC breaker disconnect but the connector didn't fully click in. Are there different MC4 standard connectors? The Wi-Fi stick was a little challenging but basically you must change the server address in the app from server.growatt.com to server-us.growatt.com and the password to unlock the setting is "growatt20231128" using todays date 11/28/23
Thanks for any advice!
Vince
vbVRFQ08KRz0A2XLZm3xDcZ4zlVzqaTs71KBqX6sKLJkkHKQmz86-diUV9aQ53cozMXBpiAe5p0fA9v21UAX53H-bmXCbBh3lUb0RXekaskSAXsuK2Zssbgm09wum6r4vEiXghB5nz6S0tL6HkFBRs8
NwE34roEk42JUbj5s-nKMDVSE38nUdCW6ous375kCEezBYmUsNQLxyXLchzFjwQP-2861iWIa1P2hjVJdeAmYJGqlusKCcPNLoFrb_V_IgcVd7jPrckUar62K3tWAgh1m-rRLKkNKz47xAqFWDjktvs
rSx2YKTcv6FRMApJjksMRuDzU3zpT2gS7DMn2eXxseWnGpe1hu1T7j9ZFZEIwJTk6-At43yD_G80a1yls_DlLJkf6fX-gqUMeIk7tlDGlgIMuW-IdIdJZqfbmMA-r3vTF-g0xRH07FWMwnWnN-yhim4
All mc4 connectors should be compatible
BUT this is not always the case,
Try push harder? (Without breaking anything!)
