Hello Solar Geniuses,
So one of my Growatts isn't using all available solar and I can't figure out why. You can see on the main window that it's showing 1749w solar, an 1892w load and it's pulling 412w from the battery. But if you look at the info window at the bottom, it's getting 3190w from the panels (100v and 31.9a).
Why isn't it using the available solar? The other inverter on the system is doing fine, but this one's using up battery during the day because of it.
Any ideas?
Setting 22 is set to solar balance enable btw.
Thank you.
Any ideas?
Thank you.
