Hi, I have two growatts spf 5000tl hvm with parallel cards.
When i try each of them in the single mode it is working ok.
When i connect parallel (one phase) it does not see the grid even when i setup utility first. i can hear clicks from the inverter as it tries to connect to the grid but never did.
It is taking all energy from panels and after that from the battery even when it reaches a low battery level setting it is still going from the battery.
So far i checked all connections it looks ok, i also had extra cables for parallel (those with green ends, small ones) I replaced it - without change.
On display i can see the Grid, voltage is ok, hertz also ok... so i don't understand that.
What is weird is it is working in single mode but not in parallel.
Does anybody had such a problem ? Any suggestions what can be bad ?
