MiroDeNiro
Hi everyone,
I am planning to switch the whole house (240V, 3P) to solar power.
Currently I have one Growatt SPF 5000 ES inverter and would like to have 3 in total to either run them in 3P or parallel 1P mode.
Is this inverter synchronising the output phase with input from grid? If not, how does the grid bypass mode work?
I am asking because I am wondering if i could have 2 or all 3 in parallel for max power available (10/15kW) and hook each one of them to a separate utility phase? so basically to combine all the rated grid power into 1P local combined power source.
Thank you in advance,
Miro
Miro
