Hi,
I recently installed a LifePO4 16s battery pack at home as a back-up battery.
It's a home-made pack, I have a Growatt SPF-5000 ES inverter and a Daly 150A BMS with a CANBUS/RS connection. I had a small cable supplied.
I followed the instructions for connecting this cable to an RJ45 socket in the Growatt manual.
When I select the battery type on LI with the L004 protocol, the inverter goes into error. Error code 20.
I've checked my cable connections.
In the Android Smart BMS application, I selected Growatt and RS485.
I tested various solutions found on the internet (except firmware updates) but nothing worked.
I'm currently using the USER2 manual settings, but is there any way to make the inverter communicate with the BMS?
Thanks
Thanks
